What model 5th wheel do you comfortably tow with your F-250 Diesel?
I had the Andersen on my RAM and it bent the hell out of the steel floor of the bed, I figure it will ruin the aluminum bed floor on the Ford.
Does your truck have the factory hitch pucks?
If so, I would do a normal puck mounted 5th wheel hitch with a Reese Sidewinder pin box.
Just wondering, but shouldn't the most significant concern be about payload capacity on the F250? our Platty only has 2200 lbs. We are looking at a 5th wheel ( Grand Design 298BH) - and with a 1500 lb hitch weight unloaded, we are going to be we well over payload...truck has airbags and the 10k package
The following users liked this post:
seems to me it would be cheaper to upgrade the emblems on the side of the truck, and get a sticker from the junk yard and olace over yours with higher payload.
are you upgrading to a f350 to tow your 21ft micro light. What's it weigh 4500lbs empty 5500 loaded? I would tow that with an f150 all day long, or even a colorado duramax.
No. We're getting it to step up to a 5th wheel in the near future. And your weight estimations are off anyways.
#28
That is the biggest challenge with an f250 and a fifth wheel. Especially a diesel, at most your looking at 2600-2700 pounds of payload with a crew cab. My CCSB has about 3100 pounds of so of room on the GAWR on the rear but only 2540 pounds of available payload due to the de-rated GVWR.
My FIL has an F250 XLT Premium, Powerstroke, CCSB, 4x4, with the 'Heavy Haul' option or whatever it's called. No fifth wheel prep, carpet delete, otherwise pretty loaded.
His payload, per the sticker in his doorjamb, is over 3k (I don't recall exactly, I want to say it's 3100?).
#29
Depends on the option packages selected.
#30
