Sponsored by: Real Truck
4r100 center support question
Old Oct 8, 2023 | 07:33 PM
Btuss426's Avatar
Btuss426
6th Gear
I have a 1999 7.3 and I’m at the part where I used air to test the forward and direct drums. When I introduce air into either port each drum activates but there is a small amount of air that comes out through the center support seal. Not the sealing rings but the round flat seal between the center support parts. Is this normal? Should there be any air?
