Gearing with 35s
Old Oct 6, 2023 | 02:08 PM
ColeJohnson419's Avatar
ColeJohnson419
7th Gear
Gearing with 35s
Hey so I have a 1995 with a 6" lift and 35s with a 302H.O and a 4r70w tranny 4x4, Has shorty headers into y pipe through flowmaster muffler, k&n cold air intake and its a brand new long block from summit racing with 800miles. It has stock 3.55 gearing at the moment and I am wondering what the best gear ratio would be for better mpg but I also do a little towing and don't want to ruin that. I keep seeing 4.10 or 4.56 to get a little better mpg but will that ruin my towing ability? I currently get 6mpg and I typically tow a flatbed trailer with dirt bikes and quads but I'm about to buy a 5th wheel camp trailer and gutting it.
Old Oct 6, 2023 | 02:41 PM
knottyrope's Avatar
knottyrope
I have a 95 F350 with 35s
its the same as Stock tires with 3.55 gears
4.56 might be too much and make you rev too much on high way speeds.
i spent some time playing around with this
https://www.g2axle.com/pages/view/gear_ratio_calculator
Old Oct 6, 2023 | 03:18 PM
JJF20's Avatar
JJF20
Here’s another calculator I’ve used.. has drop down menus for transmissions and transfer cases.. saves a bit of homework of ratios.
Gear Ratio Calculator
Old Oct 6, 2023 | 04:04 PM
Mudsport96's Avatar
Mudsport96
4.56s at MINIMUM. If you offroad alot 4.88s. I have dealt with a 94 302 auto truck with 35s personally, and it was marginal off road wit 4.56s.
Old Oct 6, 2023 | 05:32 PM
Conanski's Avatar
Conanski
Be sure to recalibrate the speedo for the larger tires.
The optimal gearing for a 5.0/OD truck of this vintage with stock sized tires is 3.55 to 4.10, so with 35's you need to be in the 4.30-4.90 gear range. The lower end of the range will delever best fuel milage while the higher end will sacrifice some of that for better towing performance. Also note that the truck will consume more fuel overall with the larger/heavier tires, expect to lose 2-3mpg across the board.
Old Oct 7, 2023 | 01:04 PM
My4Fordtrucks's Avatar
My4Fordtrucks
I went from 3.55 to 4.10 in the Bronco. I would have gone lower if I had overdrive. The swap to a 392 helped
Old Oct 7, 2023 | 02:16 PM
Prototypemech's Avatar
Prototypemech
4.88 would be ideal.
Old Oct 7, 2023 | 03:34 PM
ColeJohnson419
7th Gear
wait so ill lose 2-3 mpg after regearing to 4.56s from my 3.55s?
Old Oct 7, 2023 | 04:24 PM
Conanski's Avatar
Conanski
No your milage should increase, what I didn't include in my previous statement is that a truck would lose 2-3mpg with larger tires compared to the same truck with stock tires.. which should average around 15mpg.
cc322
6.2L V8
18
Apr 27, 2022 04:29 PM
Fireboater
6.2L V8
Apr 16, 2013 12:49 PM
firemedic2714
All Things Towing
13
Feb 27, 2013 06:18 PM
ghoyt87
2009 - 2014 F150
28
Jan 7, 2009 04:04 PM
redneck1877
May 31, 2006 02:24 PM
