Weathertech mud flaps
Unless someone wants a bigger and more big truck style mud flap like the Dura Flaps, then these won't be for you... But if you want to protect the rockers and underneath of your truck in the rear wheel wells, then these no drill mudflaps may be for you. Also, these non- drill mudflaps are advantageous for rust belt guys like me.
This is the front left... That's Mobil 1 synthetic grease that I slimed on the body and the mud flap to protect the wheel well as I don't have the Monstaliner on yet... Once that's applied then I won't need the grease... I am OVERKILL... But you have to be when you live in the rust belt and drive your truck in the winter.
They use the stock 5.5mm head factory screws to fasten to the body. They provide a stainless steel screw and stainless flanged nut for the bottom. There's a hole already there in the fender.
The rear mudflap... That's Green Grease, which I didn't have when I mounted the fronts first, between the body and mudflaps. That Green Grease is some tenacious and tacky grease.
Good schitt...
Provided stainless hardware.
The bottom screw all gooped up...
with Fluid Film.
The other side rear flap.
Anyways, knowing what i know now, I would have had Monstaliner on the body when the truck was new which would have protected the body and I wouldn't have to prep and paint with Chassis saver.
Next year, I plan on removing the rear wheels and getting underneath the well there and the body, paint with Chassis saver if need be, as there are a few spots, then prep by sanding first and then applying the Monstaliner inside and along the body lines.
I just wanted to install mudflaps to see how they do with the snow and if they keep some out of the wheel wells... we shall see. She's getting oiled in early November at Carwell Products again.
You have the plastic wheel well liners installed?
Last year I did the silver Chassis Saver first, which contains more aluminum, then the satin black on the driver's side... that's some crazy paint Troy. If it has seasoned steel to stick to with rust present just make sure to knock off the loose stuff . To me, covering the properly prepped rust and solid paint in that area, with the Chassis saver paint, then sanding that and covering with the epoxy Monstaliner is the way to go. On the outside and the inside... Next year, I'm popping off the wheels, getting her *** off the ground on stands, sitting underneath to do my thing with my headlamp on...
I refuse to let Buffalo winters rot my truck away... they are too damn expensive to replace and who the hell wants another expensive payment... not me...
I've got another thread coming on what I just did and my brainstorm idea for the bed... stay tuned.
I'm not qualified to make any comments since I don't have any mud flaps.
