shifting problem continues
The problem is after sitting most of the summer, the four wheel drive doesnt work. I have checked your archives and no help.
The wiring diagram I have doesnt help with locating certain modules. My wiring diagram shows the wires going from the tranferr case through the floor, but from there i have no indication on where it goes. forget colour coding one side of a conecctor has one colour while the other is totally different.
There is no power geting to the over head touch pad . there is no power getting to the shift motor.
The tranny shop said if i replace the connector below the brake power booster, that it would solve the problem, but they wont take the time to do it, they want me to do it and then bring it back in.
Iam open to suggestions, I have tried introducing a power source at the touch pad but still no power gets to the shift motor.
if any one knows any thing about the wire trail, please let me know.
thanks
Another thing you might want ot look at is the limmits in the shift motor. they tell the shift module were the tras. case is, 4 high, 4 low or 2 high. Unless the module knows it will not even try to shift.
Good luck.
