Hello all
I am going to go check out a 94 F250 Super Cab today. 4x4, 7.3L power stroke with 215k miles. 5speed manual. Looks fairly clean and has had a lot of upgrades to include a tuner, south bend clutch, 4” exhaust, and more.
This is my first diesel so I’m hoping for some advice on what to look for and inspect while I’m there.
price is 9k, does that sound fair?
thanks for all your help!
Reason: Incorrect KBB value
Do you have any tips on things I should go over? This is my first Diesel, not entirely sure where to even start. I am familiar with checking for blowback and will do that. Anything else super easy I can check with some basic tools?
compression test would be great if possible
look for leaks on front cover but oil pump usually is the cause
oil cooler rebuild is easy if leaking
check for vibes
check for smooth running
check front end out well, mine was trashed from hauling 500 gal of water from PO
might have orange boot of death on turbo inlet, they crack below that most dont see
Be prepared to spend some money in repairs, at 25 years old, they will need some TLC
Read up on some builds and see what some of us have gone though
+1
My first thought was that I guess the front end is worn out with that many miles. The original poster probably knows this, but beware of crazy/weird wear pattern on the tires that the twin traction beam axles will cause when they’re worn out. Of course, the owner could conceal that a little bit by swapping tires before you get there, but still something to watch for.
I would say it depends on what your mechanical skill level is. Some things such as glow plugs, brakes and accessory items can be done by you, I wouldn't consider a deal breaker. But expensive items like tires, injectors or worse, are. I would ask the owner if you could start her up while cold without the block heater being plugged in prior. You can check with your hand when you get there to see it. But even the small items can add up.
also, check the fuel filter to see if it has been taken care of. And from what I heard, if it has a k&n filter don't buy it.
A weak pont in these trucks are the automatic transmission if it's equipped. Pay attention to the feel of the shifting.
