I am swapping to a later model 5.0 engine that requires the use of an electric fuel pump..the one I have is one that pushes more than pulls(like a Holley red type)
My question is since it doesn't pull the fuel like a mechanical pump would, do I need to replace the rear fuel supply line with something unbent. The original line has multiple upward bends here and there and just not sure if the fuel will flow properly from the tank to the electric pump.
