Clutch pedal?
Old Nov 20, 2003 | 10:25 PM
Screamin T/A's Avatar
Screamin T/A
Clutch pedal?
My clutch pedal is acting weird. Been that way since I bought the truck. When i press the pedal down and then let it back up easily, it wont come all the way up. It stays about 2 inches lower. I then have to kind of blip it up with my foot. But when I'm going at a decent pace with the truck and I shift, it comes all the way up? I dont know how else to describe it. the clutch works fine though. Any thoughts?
Old Nov 20, 2003 | 10:40 PM
neverenough's Avatar
neverenough
The clutch is out of adjustment. Too much play in the linkage. Under the truck there is a threaded rod that goes between the clutch fork and the pivoting arm. Loosen the lock nut, turn the other nut so you have about 3/4 inch of play in the peddle, tighten up the locking nut.
Old Nov 20, 2003 | 10:47 PM
Torque1st's Avatar
Torque1st
Posting Legend
The return spring under the dash could be broken also.
Old Nov 20, 2003 | 10:58 PM
Screamin T/A
i have adjusted the clutch, and it works for a little bit then about after a week or two of daily driving it starts to do this again? Am I not adjusting it right?
Old Nov 20, 2003 | 11:42 PM
hillbillyk's Avatar
hillbillyk
check the nylon bushing for wear on the clutch linkage under the truck, also might need to grease these parts, I greased mine when it was doing the same thing and it worked fine.
Old Nov 21, 2003 | 09:00 AM
KJKozak2's Avatar
KJKozak2
Mine 79 does that too. Exactly as you describe. If you tap it from the back with your toe, it pops all the way up, so I think the spring is still there. I only use it for a plow truck in the winter so I never bothered to fix it. Perhaps this weekend.
Kevin K.
Old Nov 21, 2003 | 01:55 PM
77'F-150Mudder's Avatar
77'F-150Mudder
My truck has recently developed the same problem. Before I put it on the road I re-bushed the clutch rod after welding up and re-drilled the lever under the dash and the z-bar (the holes were extremely elongated).
The spring under the dash seems to be OK. I believe my problem to be a weak return spring under the truck. It was half "sprung" when I had it off so I'm almost 100% sure thats the problem.
Old Nov 21, 2003 | 02:05 PM
KJKozak2's Avatar
KJKozak2
Guess I'll have to strap a bungee to mine.
K.
Old Nov 21, 2003 | 11:17 PM
jbury's Avatar
jbury
You know K. that bungee cords are a pretty sophisticated fix. Me, I like using old cut up innertubes from the bicycles I ran over...
Old Nov 22, 2003 | 12:45 PM
clean79150's Avatar
clean79150
I agree with Neverenough, I had the same situation, and adjusted the clutch, and it's been fine. Just make sure that the locking nuts are not working themselves loose, give them a good turn into each other.
