Are they supposed to be greased as both i have were not and i greased the one i am using that had 11,000 on it.
If they are not supposed to be greased then how do they keep from wearing out in only a couple hundred miles?
The service manual indicates that the release bearing should not be cleaned in a solvent as they are pre-lubricated. There are no lubrication instructions.
The maintenance lubrication section mentions lubricating the clutch release equalizer shaft, but not specifically the bearing.
Well your a 50 series my 55 bearing has grease maybe they are different and lubed with graphite. I bought my bearing and a new fork on eBay. The thunderbird was different, when I compaired it to the fork that was causing problems with my first gear. Only. My truck is three on that oil tree.AJ
T/O bearings are supposed to greased, they come new greased but if you are reusing one you can clean out the old grease and then hand pack it(as most do not have a zerk)
my throwout bearing was sloppy and had no zerk and no grease so i packed mine like a wheel bearing with wheel bearing grease and it spins very smooth now and has no wiggle.
