Sponsored by: Real Truck
Tow Hook Oops......
Old Sep 20, 2023 | 10:46 AM
PJWhelan's Avatar
PJWhelan
Tow Hook Oops......
I have a 2002 F-250 with 235,000 miles and was trying to remove the tow hook bolts (3) per hook. I sprayed them up with PB Blaster and first used an impact wrench. First mistake. Pretty sure i snapped the bolt cause it just spins and the top threads don't. The nuts are tack welded on. So to test a theory, I moved to the right side to attempt to remove one bolt. This time I heated the be-jesus out of it, sprayed the "get 'em off juice", and first used a ratchet on it and sure enough it loosened up. So, guessing that method works well for 21 year old bolts. Now, how would I get out the bolt that is spinning on the left side tow hook? Space is tight as you all know. Any ideas?
Old Sep 21, 2023 | 04:40 PM
bajaphile's Avatar
bajaphile
I relocated mine a few years ago, so I can't remember the stock configuration -- are the welded nuts on the back the only threaded portion that the bolt utilizes? If so, you should be able to remove the other bolts and the one you broke would just fall out. Once you got the hook off I'd imagine you would be able to get on the seized portion of the broken bolt with a stud extraction tool, vice grips, pipewrench, whatever you've got to try and unthread it.
Old Sep 22, 2023 | 05:02 AM
Mac Daddy's Avatar
Mac Daddy
Can't stick if it's liquid...oxy acetylene torch for the win.
Good luck!
-Mac
Old Sep 22, 2023 | 08:51 AM
PJWhelan's Avatar
PJWhelan
So the best I have is mapp gas. I'm thinking to heat the nut up until it gets beet red and knock it loose with a cold chisel. The bolt head definitely spins but upper remnants of the top bolt don't. It's what I get for experimenting.
Old Sep 23, 2023 | 11:22 AM
super 6.8's Avatar
super 6.8
If you have access those nut breakers work pretty good.
Amazon Amazon
Vinford
Dec 28, 2020 11:03 PM
Byos
Aug 7, 2009 08:12 AM
GonzoCSU
Jun 8, 2007 09:56 AM
o2civic
2004 - 2008 F150
17
May 26, 2007 11:52 AM
timmyjimmy5150
1997 - 2003 F150
Mar 7, 2006 06:43 AM
