Cutting out at light throttle
Old Sep 14, 2023 | 09:40 AM
belchfire's Avatar
belchfire
1990 F250 351W 4x4. The truck idles fine & accelerates OK it's just when I'm cruising at light throttle that it cuts out. It feels like it's electrical as it's a quick on-off. I've replaced the TPS, EGR position sensor. Plugs,wires,& coil are < a year old. Ignition switch is new. Wiggled the hell out of all wires. Fuel pressure's OK w/new pump in the front tank. This has been going on for years so I'll replace something & it seems to clear up only to return. Maybe the MAP?
Old Sep 24, 2023 | 06:08 PM
belchfire's Avatar
belchfire
Somewhere else I heard the PIP mentioned. Not knowing what that was, I looked it up & determined that it was the sender in the dist. I changed it out & it seems to have done the trick. I'm use to the DS II systems that are pretty much bullet proof so that's the last place I thought of looking. Many years of frustration with this one.
belchfire
Sep 14, 2023 09:10 AM
Jo7.3
Jun 20, 2023 07:53 PM
blackgold50
Jul 22, 2014 03:40 PM
Quick69
Nov 4, 2010 10:57 PM
seatea
Jan 16, 2001 08:59 AM
