Sponsored by: Real Truck
Rear Camber
Old Sep 12, 2023 | 09:50 PM
Slaughery's Avatar
Slaughery
4th Gear
Rear Camber
I have a 2000 F250 with a negative rear camber.
What could cause this?
Old Sep 13, 2023 | 12:52 AM
99f350sd's Avatar
99f350sd
Bent axle or housing.
Old Sep 13, 2023 | 01:37 AM
Slaughery's Avatar
Slaughery
4th Gear
No way it could be shocks and struts?
Old Sep 13, 2023 | 05:16 AM
jade97's Avatar
jade97
No, a super duty doesn't have struts & shocks are just dampers. You can drive the vehicle without shocks. The super duty has a solid axle and leaf springs....it's most likely bent.
Old Sep 13, 2023 | 06:16 AM
99powerstrokedF250's Avatar
99powerstrokedF250
As jade said, unless the axle was machined improperly (unlikely), it's hard to get negative camber on a solid rear axle since everything is fixed in relation to each other in the axle itself. If you've got camber in either direction, it is likely bent.
Old Sep 13, 2023 | 10:55 AM
Slaughery's Avatar
Slaughery
4th Gear
Thanks for the help
Old Sep 13, 2023 | 09:11 PM
bajaphile's Avatar
bajaphile
Just curious, what is the measured camber? Anything under a degree would probably not mean much.
On jackstands, can you wiggle the tire at all from holding it at 12 and 6 o clock? There is a slight chance that the axle nut(s) was not torqued properly and allowing the hub to have enough play that they'd read a slight negative camber when weight bearing.
If the axle is indeed bent, it wouldn't be too big of a deal, plenty of rear axles out there you can swap out with. If your truck is 4x4 just make sure you've got the right gear ratio.
Old Sep 13, 2023 | 09:34 PM
Slaughery's Avatar
Slaughery
4th Gear
I do not know. The tires wear quickly and unevenly on the inside of the rear tires. New ones lasted about two months before I noticed it.
How do I figure out the gear ratio?
grantpa
2009 - 2014 F150
Dec 27, 2024 11:07 AM
ASFC27FTFBQ
Mar 10, 2022 11:37 AM
Alpinweiss
Jan 28, 2022 06:44 PM
foglght
Aug 9, 2021 12:27 PM
v10kenj
2009 - 2014 F150
Jan 10, 2014 10:10 AM
