Silly , Dumb ,Same ol , thang
Old Sep 11, 2023 | 04:12 PM
RTT's Avatar
RTT
Will took fan bolts out & I can not get bolts to re-install ................So what am I doing wrong ???????????????????
Old Sep 11, 2023 | 04:22 PM
RTT's Avatar
RTT
I guess the pulley & water pump snout have to line up ? I see threads on back side is what has me so angry.........I guess these are not the threads I need to screw into first !!! I don't know .
It is always some dumb .........problem........................ oh..........me............
Old Sep 11, 2023 | 06:58 PM
351Cleveland C4's Avatar
351Cleveland C4
It can be difficult to get all 3-4 pieces lined up again, but it's just that, getting them lined up.
Old Sep 11, 2023 | 08:18 PM
RTT's Avatar
RTT
Calmed down & I got a bolt fairly easy with an awl lining up a hole and rest was fairly easy . Put a little oil on the bolts after wire brushing them & wiping off dirt............
Old Sep 12, 2023 | 12:14 AM
Christmas's Avatar
Christmas
You must have pulled the radiator in order to use an awl.
Old Sep 12, 2023 | 12:52 PM
FuzzFace2's Avatar
FuzzFace2
For next time, there will be a next time
Get a bolt that will thread into 1 of the holes that is a little longer than the factory bolts and cut the head off then cut a slot across it for a screw driver.
Now thread this into 1 if the holes now you can install the parts on the water pump using that bolt you made to line it all up and get the other bolts started.
Once you have the other 3 in use a sscrew driver to remove that bolt you made and install the last bolt.
Dave ----
Old Sep 13, 2023 | 02:34 PM
RTT's Avatar
RTT
Wink
Dave ----
I tried something similar already but quickly realized that it will not work because there is a 3" spacer between the fan & pulley
Your method my work but I had pretty good luck with the awl . I was very careful not to hit the radiator , but the cardboard idea I will probably do with using the awl
Old Jan 13, 2025 | 09:53 AM
jtpasto's Avatar
jtpasto
Try Grainger or Fastenal.
Dweber319
Jun 25, 2022 10:58 AM
Carolina Rig
Oct 11, 2021 01:16 PM
Oldanvilyoungsmith
Sep 27, 2016 10:25 AM
tjdad62
Nov 20, 2010 06:53 AM
rcav8or
Feb 28, 2008 09:10 AM
