2018 Electrical problems
Old Sep 4, 2023 | 04:46 PM
can-do-man's Avatar
can-do-man
2nd Gear
Middle of June lost alternator, local dealer replaced alternator and battery. 30 days later started getting the following messages, "hood Ajar", collision assistance not working, No r/h front headlight or turn signals, no horn, no adaptive cruise, no auto start. and an occasional over heating alarm. Have disconnected and re connected the battery, helped one time. A trip to the dealer, 3 hrs diag. time and $6xx.00 and they wanted to start replacing all the components. Driving home this last week and everything worked fine for 10 minutes and then started getting the same display messages.. Have some suggested loose wiring/ground. I would have thought so but where do i START! thanks, Truck had 99K on original alternator and battery.
Old Sep 5, 2023 | 09:36 AM
JKBrad's Avatar
JKBrad
Welcome to FTE can-do-man,
Try checking the ground cable, both ends to make sure that is is not lose. If you see any corrosion on it that goes under the insulation, replace it.
But it sounds more like you could have a pinched wiring harness somewhere near the front of the truck. Has it ever been in a wreck?
Old Sep 5, 2023 | 10:00 AM
can-do-man's Avatar
can-do-man
2nd Gear
thanks
It has not been wrecked. I will check the cables.
Thanks John
JustAJ
1997 - 2003 F150
Jan 30, 2013 08:36 PM
Eric H
Jan 30, 2013 12:01 PM
crzyldy35
1997 - 2003 F150
Jan 31, 2010 11:30 AM
2003 Stroke
Aug 1, 2007 09:18 PM
Palani4Ford
Apr 3, 2002 10:04 AM
