Front lower cab hinge mount work to be done
Old Aug 31, 2023 | 08:27 PM
Bluey Zedoff's Avatar
Bluey Zedoff
Guys, had to cut the old hinge out due to it being totally rusted and now am faced with welding the new piece in.
Bought this piece from Denis Carpenter and it seems pretty good, though the hinged area looks a little flimsy, the actual frame is made of reasonable steel.
Of course, like an ignoramus, I cut a tad too much steel off the new piece and now it's a couple of mm too short. The plan is to slide some copper plate behind the weld
and weld this new section on.
Tell you what, I am sh*****g bricks over this as the alignment has to be super spot on. I have measured the distance between the centre bolts from one hinge to the other on the side I haven't tampered with, so
I should just match that with the new piece and theoretically the hinge should mate up with the door when I fit it up.
Wish me luck!
I have to pull the rocker panel in a bit to get this bottom section to sit flush. I think I'll do this after I get that hinge piece centred and tack welded
Old Aug 31, 2023 | 11:24 PM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
I would test fit the door while everything is firmly tacked into place, before finish welding.
Old Sep 1, 2023 | 11:23 AM
52 Merc's Avatar
52 Merc
Reading through the post I was going to respond the same as Effie. Tack everything together and test fit all the parts for correct fitment before final welding. It will save a whole lot of heartache later.
Old Sep 1, 2023 | 03:05 PM
pintoplumber's Avatar
pintoplumber
Instead of copper, how about using a piece of steel and letting it in place, welding everything up?
Old Sep 3, 2023 | 04:22 AM
Bluey Zedoff
Good news guys. It lined up fine. Fitted door up pretty well, but still early days. Once rubber seal is fitted and door latch etc, then we'll see, but at least the hinges lined up.
Old Sep 3, 2023 | 04:25 AM
Bluey Zedoff
Yes, we ended up adding in some reinforcement there. Can never have too much support. Agreed 💯
Ctmlb34
Aug 13, 2022 02:55 PM
KirkF
Feb 19, 2021 06:34 PM
slashfan7964
166
Aug 16, 2020 11:08 AM
axman_F250
Oct 12, 2011 08:07 PM
gdub
Sep 26, 2011 10:22 AM
