2001 7.3 excursion leaking coolant while running
Old Aug 30, 2023 | 09:56 PM
machoman111's Avatar
machoman111
1st Gear
So I pulled my excursion in today to work on the brakes, was walking around the front and noticed a trail of drops on the floor. Looked underneath and noticed coolant dripping profusely from the back, passenger side of motor, all the way down onto the starter then to the floor. Anyways it quit dripping after about 5 minutes. I started it back up and watched it just leak a bunch of coolant coming from the same spot. There is nothing in the valley other then some oil but we will save that for another time. And it also isn’t coming from the heater hoses or whatever people were calling them. I’m not sure what it could be, any advice would be helpful. Thanks!
I also attached a video of the leak.
File Type: mp4
Old Aug 31, 2023 | 04:15 PM
udsuth78's Avatar
udsuth78
If it definitely isn't the heater hoses that only leaves the heater core or a blown head gasket doesn't it? You could try pressurizing the system so maybe you could track it without the engine noise.
Old Sep 1, 2023 | 11:08 PM
callforfire's Avatar
callforfire
Or that crossover tube on the firewall is rotted on the end.
Old Apr 13, 2025 | 02:11 PM
tomhinds's Avatar
tomhinds
4wd Low
Did u ever figure it out? Mine is doing the same thing.
Old Apr 14, 2025 | 10:45 AM
Eman85's Avatar
Eman85
What have you checked?
Old Apr 14, 2025 | 10:51 AM
tomhinds's Avatar
tomhinds
4wd Low
Looked at all heater hoses except the far left one which I believe is the pressure side of front heater core. Leak traced up to back top right of block above right of freeze plug. No pressure test yet.
p.ward7885
1978 - 1996 Big Bronco
Jul 28, 2013 07:44 PM
dalestotlar
Jul 4, 2013 09:38 AM
reddog99
1983 - 2012 Ranger & B-Series
Jun 21, 2012 09:24 PM
Cofooter
Apr 1, 2010 03:54 PM
slowone
Jul 31, 2006 11:50 AM
