2022 DEF issue anyone?
Old Aug 30, 2023 | 04:43 PM
Big Dog00's Avatar
Big Dog00
2nd Gear
22 F350 and my DEF light is on with 1/2 tank of DEF. I topped it off, and it showed 1500 miles left on full tank of DEF, previously a full tank would show 6000- 8,000 miles. Anyone had this issue? Goes to dealership Tuesday. Thanks
Old Aug 30, 2023 | 05:45 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Your first post, I take it this truck is new to you?
Your experience with the DEF system on your truck is normal for a 22, mine acts the same way.
I would bet the miles will update after you drive it for a while.
Also, when you say you filled it, how did you fill it, at a truck stop pump or by jug?
There is about 1.5 gallons of DEF capacity above the full reading on the gauge, so if you just added a jug, it won't be completely full.
Old Sep 1, 2023 | 10:12 AM
Big Dog00's Avatar
Big Dog00
2nd Gear
Nope!
Nope, ordered truck new, been driving def diesel for years.
I FILLED DEF at pump to full, went to 1700 mile range, about 4 days later, still 1/2 tank DEF, light comes on, says only 400 miles, refill now.
Never took it down to see if it would restrict rpm's as I was on the road traveling. Never had anything close to this, can't wait to delete it
Old Sep 2, 2023 | 09:20 AM
rhino_160's Avatar
rhino_160
Def NOT normal. I have a '22 F350 platinum and the light should not be on until it's truly low. My light can be on and I can add 2 gallons and easily see it climb and give me well over 1000+ range and the light turns off.
I have about 1/4 on the gauge right now and show over 1500 miles to empty.
At full, I get around 7-8k miles I do believe. Def get it looked at.
Old Sep 2, 2023 | 03:17 PM
senix's Avatar
senix
sounds like it is confused.
I have always recommended letting it do the count down to <200 to empty and then a complete fill to avoid this very issue of confusion.
wiresLV
Feb 8, 2022 04:45 AM
Badford
Jan 18, 2020 03:27 PM
crewzer
Nov 19, 2018 05:40 PM
Snellville-Dave
6.7L Power Stroke Diesel
22
Nov 2, 2014 07:42 PM
Stroker 94 1/2
31
Mar 14, 2009 10:54 AM
