2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Who's Running A Dash Cam?
Old 08-29-2023, 10:37 AM
redford's Avatar
redford
redford is offline
Received 1,628 Likes on 952 Posts
I use a Garmin Dash Cam 57. Easy to use, all voice commands, decent picture quality. I need to get my lazy rear-end in gear and hardwire it to some power.
Old 08-29-2023, 12:32 PM
explorer003's Avatar
explorer003
explorer003 is offline
I have the Thinkware brand Dashcam. The video quality is nice and it is user friendly.
I am a firm believer in their use. The attached video helped me get their insurance to cover the cost of damages. The driver of the car told the police and his insurance the accident was my fault.
File Type: mp4
Old 08-29-2023, 02:38 PM
F150Limited's Avatar
F150Limited
F150Limited is offline
4wd Low
I have the Blackvue DR970X 2 channel and a Blendmount mounting bracket. This is the 5th Blackvue I have purchased.
Old 08-29-2023, 02:58 PM
MKrenn's Avatar
MKrenn
MKrenn is offline
Not gonna lie. I bought Chinese. The memory card costed more than the cam. I don't drive in a lot of traffic, but, occasionally have an idiot of 2 that I run across.....Have not had to download anything to prove a point yet, but, at least I can if needed....
Old 08-29-2023, 04:52 PM
HorizontalHunter's Avatar
HorizontalHunter
HorizontalHunter is offline
One of the things I like about the Blackvue is that it will tell you “an impact was detected in parking mode” if the truck was bumped or the tailgate was slammed😁. It can be a good reminder to get out and take walk around the truck to double check.
I had my truck less than a month when it got “punched in the nose” in the parking lot folding over the front license plate.😡
The following 3 users liked this post by HorizontalHunter:
Old 08-29-2023, 05:21 PM
rmrrm's Avatar
rmrrm
rmrrm is offline
Originally Posted by kshoop1958
About a year ago I bought a Rove R2-4K for about $120, plus a Samsung 256Gb SDXC memory card for about $40, plus a Donger Technologies rearview mirror power adaptor for about $30. Easy peasy because no wiring was required and the video looks good enough for me. Pretty sure you do need an "auto-dimming" rearview mirror for the Donger adaptor to work. No problems so far except the suction cup gave up once or twice in the heat.
Good luck!
I'm running the same exact setup, but caught the camera on sale for under $100 on Amazon. No issues so far.
Old 08-29-2023, 05:29 PM
ATC Crazy's Avatar
ATC Crazy
ATC Crazy is offline
Received 2,823 Likes on 1,370 Posts
Don't kick yourself. They are ALL chinese. In fact, there are only a couple different cameras...the main differences is all in the plastic case they are mounted in.
Check out the 10:30 mark for an explanation.
The following 3 users liked this post by ATC Crazy:
Old 08-29-2023, 06:04 PM
cadent49's Avatar
cadent49
cadent49 is online now
Originally Posted by ATC Crazy
I use a BlackVue DR590W. Love it, and has worked flawlessly for over 3 years now.
BlackVue DR900S for me. Flawless operation for more than 5 years
Old 08-29-2023, 06:39 PM
Monoman67's Avatar
Monoman67
Monoman67 is offline
Originally Posted by acdii
Wolfbox G840s. Mounts to the mirror, has GPS and a rear camera. The only thing I don't like is that the camera case on the truck (for the highbeams and collision alert) blocks a small part of the view and the mirror is off a bit, but I rarely use the mirror and can switch to the rear camera view instead.
I returned mine. I found that it shook a bit on the mirror and when it was off to be used as a regular mirror it was washed out looking in some areas. Maybe I got a bad one. Gonna probably try a BlackVue next.
Old 08-30-2023, 03:35 AM
Garbageman 134's Avatar
Garbageman 134
Garbageman 134 is offline
How did you route the wires from the front cam?
Old 08-30-2023, 05:42 AM
HorizontalHunter
I ran the wires up/down the passenger side pillar, behind front door weather moulding, down the passenger side door sill, up the rear pillar, and I tucked the wire up under the rear edge of the headliner.
My power source was in the passenger side foot well as I am using upfitter switch #6 to control the power to the dash camera.
Old 08-30-2023, 08:40 AM
DSLTRK60's Avatar
DSLTRK60
DSLTRK60 is offline
https://www.youtube.com/watch?v=4AnyhHl3_tE
Not all of them, My camera was made in Korea.
  #28
Old 08-30-2023, 10:50 AM
kshoop1958's Avatar
kshoop1958
kshoop1958 is offline
The Rove also has that feature. So far, thankfully, it's only gone off from something I've done like slam the tailgate. You're right though, it is a good reminder!
The following users liked this post:
  #29
Old 08-30-2023, 03:57 PM
acdii's Avatar
acdii
acdii is offline
Received 2,088 Likes on 1,423 Posts
The Wolfbox has that if you hard wire it. I had it for nearly a year and just got around to hardwiring it. The mini fuses held me back trying to find the add a fuse for them.
  #30
Old 09-03-2023, 02:21 PM
Bair1218's Avatar
Bair1218
Bair1218 is offline
What fuses did everyone tap into for ignition and constant?
Quick Reply: Who's Running A Dash Cam?
