Fob quit working
Old Aug 28, 2023 | 09:33 AM
bertscw's Avatar
bertscw
Fob quit working
I'm sure this has been covered but I couldn't find any reference to it.
My fob just quit working yesterday, worked Saturday without issues, batteries were changed in both fobs in June. I put the battery on my meter and get 3 volts as it should. I, of course, will change the battery but am wondering if others have experienced a similar failure?
Are there any troubleshooting procedures?
If it is a goner, replacement suggestions?
2019 F250 Limited and original fob (it is the one used almost all the time)
TIA
Old Aug 28, 2023 | 09:48 AM
Wildwr's Avatar
Wildwr
4th Gear
Check this link out as they talk about the hidden key fob slot. this may help determine if it's a battery issue or keyfob is dead
All the Ford Key Fob Tricks You Need to Know | GetJerry.com
Old Aug 28, 2023 | 04:34 PM
function12's Avatar
function12
Is your truck battery low?
See if it will lock and unlock with the truck running.
Old Aug 28, 2023 | 05:49 PM
bertscw's Avatar
bertscw
Update, the other fob works as normal so the issue isn't the truck.
I used the bad fob to start the truck using the cutout in the center console. I guess that means the fob isn't completely shot. I still need to get a battery, tomorrow after work. I would swap the battery from the good fob but I'm not taking a chance at breaking the only good fob I have...
Old Aug 28, 2023 | 11:13 PM
Flyct's Avatar
Flyct
FTE Community Team
If you get your fob working you may want to get another one and program it yourself. You can self program if you have 2 working fobs. If you only have one you need to go to a dealer or locksmith.
I always get a at least one additional spare with any car or truck I buy.
oEM fobs for $79 https://myaccount.carandtruckremotes...rchmodel=F-350
Old Aug 29, 2023 | 06:57 AM
jcb206's Avatar
jcb206
Excellent advice. That’s a lot cheaper than the dealership will charge you.
Middlemore
May 10, 2023 06:44 PM
jerworrall
Aug 17, 2021 01:25 PM
Big-Red-Lariat
2015 - 2020 F150
May 20, 2018 09:13 AM
Bullitt390
2015 - 2020 F150
Nov 29, 2016 10:26 PM
cmalley12
6.4L Power Stroke Diesel
Dec 3, 2012 08:29 PM
