Frame replacement/repair
Old Aug 23, 2023 | 02:24 PM
aaronk10785's Avatar
aaronk10785
2nd Gear
Any constructive suggestions appreciated on replacing part of or all of my 2000 Excursion frame. It's mostly trash in the front and back in between not so bad. I was thinking to remove the body and then cut off the worst and replace it with 1/4 or 3/8 in and match as close as possible height and width. Then the less bad weld 1/4 or 3/8 sheet metal. To raise the body off the frame was planning a gantry and engine hoist both 2 ton capacity then sitting the body on 4x4 timber between cider blocks or steel 55 gallon barrels. My ultimate goal is recreation and towing for same.
Old Aug 28, 2023 | 08:19 PM
72GTS's Avatar
72GTS
Find a rust free replacement frame. Lots of areas to look for them.
Old Aug 31, 2023 | 12:04 PM
fordiesel69's Avatar
fordiesel69
I must ask for pure curiosity, what about the floor, rockers, fenders, and cross beams on the body?
suthernboi4lyfe
Dec 8, 2013 08:07 PM
BrentKasson
General Automotive Discussion
May 1, 2005 06:46 PM
Papi_Tuck
Dec 6, 2003 02:13 PM
