Erratic Steering
Old Aug 22, 2023 | 07:34 PM
Jeff M.'s Avatar
Jeff M.
Trailering
Erratic Steering
Hi everyone,
I bought my 17 F450 with just under 40k on it, when I bought it the track bar was loose so I swapped it and the ball joint (Moog). I have only put 20k on it and I can't honestly say the steering has ever felt that great.
1) If I hit the rumble strip it is like it becomes impossible to steer. It takes big changes to get it to move off of it.
2) It tracks in grooves in the road really bad, it is like it seeks them despite where I steer it to go.
3) Just in general steering is a chore, it seems unpredictable. (Alignment?)
I noticed that the drag link has maybe 1/16" of vertical play in it so I guess I'll start there, but what I can't believe is the axle is able to move side to side at least 1/4" each way. The bushing in the track is still super tight, but the track ball joint allows it to move slightly side to side (not at all up and down). Does that mean this track bar ball joint is bad as well? If so are there brands better than Moog for the F450? A lot of aftermarket stop at F350. I can get the new Moog part under warranty but I don't want to replace it every 15k.
Thanks,
Jeff
Old Aug 22, 2023 | 09:14 PM
Ding126's Avatar
Ding126
add a new stabilizer ( not OE ) or add a dual stabilizer when all other attempts fail
Old Aug 22, 2023 | 09:19 PM
Jeff M.'s Avatar
Jeff M.
Trailering
I put a Fox steering stabilizer on it back when I first got the truck, it is probably the only reason I haven't gotten the full blown death wobble.
Old Aug 22, 2023 | 09:23 PM
Joe T's Avatar
Joe T
There are some front steer tires that people recommend on here. Maybe search or someone will chime in.
Matt03Expy
Jan 17, 2022 06:46 PM
Philisophe
Oct 30, 2018 10:59 PM
Team Violence
Dec 26, 2009 10:38 AM
StanleyZ
Dec 8, 2008 09:30 AM
jetjock16
Feb 20, 2004 10:02 PM
