Sponsored by: Real Truck
rear differential gear oil replace
Old Aug 21, 2023 | 11:15 AM
Retired 2020's Avatar
Retired 2020
Trailering
On a 2011 Ford F250 with AOD transmission electronic limited slip do you need to add a friction modifier when changing the rear differential oil....thanks
Old Aug 21, 2023 | 03:57 PM
apache84's Avatar
apache84
You better check whatever brand you buy. Anymore some are only good for "top off" while others contain the friction modifier for a full fill up.
Old Aug 22, 2023 | 06:54 AM
Akley88's Avatar
Akley88
if it has the e-locker it doesnt need friction modifier. just needs to meet ford's specs. in my 16 with e locker i have run valvoline for the last 25k miles since my gear swap. ill be changing it in 5k miles.
billgrant
May 25, 2021 11:56 AM
renoduckman
May 6, 2012 03:31 PM
pbjohns
Oil & Lubrication
Jan 15, 2007 10:34 AM
f150ronnie
Oil & Lubrication
Apr 12, 2005 05:13 AM
phoneman
Mar 21, 2004 06:53 AM
