Custom or different doghouse
Old Aug 12, 2023 | 08:00 AM
Meatwagon 2%'s Avatar
Meatwagon 2%
3rd Gear
I have a 2005 e250 . I'm looking to maximize my space and was wondering if anyone has any leads on alternative doghouses , the only ones I've found are all the same generic one
Old Aug 12, 2023 | 09:29 AM
tabijan's Avatar
tabijan
The design is limited by the cutout. I’ve only seen them bigger in custom vans and RVs.
Get a spare doghouse then cut away all but 3-4” from the seal. Dummy up the tightest fit you can manage with a wireframe fill in with fiberglass. Leave some clearance for engine movement and airflow.
I think you can only shave off the cup holders and pocket. You’re not going to make space for more front row seating or a wider front passenger footwell.
Sixto
07 E350 5.4 195K miles
Old Aug 13, 2023 | 05:08 AM
JWA's Avatar
JWA
The engine cover as typically found in E-Series is two pieces, the actual cover shell and the drink holder for lack of a better term. Going back to about 1997 up to 2008 or so there should be three different choices, all if which are simple to change.
Here are two examples:
Version 1
Version 2:
This one also shows up in an eBay search, not sure if it will also interchange:
Version 3
Hope this helps!
Old Aug 13, 2023 | 06:32 AM
manicmechanic007's Avatar
manicmechanic007
Leave it alone
The engine needs the air space
Lose the cupholder if necessary
Old Aug 13, 2023 | 07:03 AM
JWA's Avatar
JWA
Leave it alone
The removable cup holder or center console are located 100% inside the cabin and don't intrude into the actual engine bay at all.
Old Aug 13, 2023 | 08:31 AM
tabijan's Avatar
tabijan
I assumed the OP is maximizing cabin space. I didn’t think of the question as maximizing engine bay space.
Sixto
Old Aug 13, 2023 | 04:21 PM
manicmechanic007
I am saying leave the engine space alone and the only thing you can remove is the cupholders and cubby
Right, he is tired of banging his knees when getting in the drivers seat like all of us
mrwrench
Nov 10, 2020 10:11 AM
blwn88cpe
Dec 3, 2004 11:36 PM
