Brake booster and MC combo w/cruise. Where to get?
I have a 1995 F250, 2wd, auto and need recommendations on brake booster and MC w/cruise control, preferably sold as a combo. I purchased a Cardone brake booster about a year ago and it failed. Reinstalled original again which is worn out (hissing when pressing pedal) and is progressively failing do to its old age. Just want to purchase a reliable booster and replace the MC this time but having trouble finding an MC with cruise. Any recommendations on what/where to purchase and write up on correct procedure would be appreciated, Also will be replacing the rear drum brakes too, any tips about this process would be great. Thanks for taking the time to read.
AutoZone has it
ask for the AC version
you have to swap the rear adapter over though
dont forget the booster tool to measure clearance
take apic of rear drums brakes before you dis assemble
loosen axle bolts and check wheel bearing torque first
i only needed pliers and a Philips to pry the springs, pretty easy to do IMO
lube those ebrake cables and pivots well
The following users liked this post:
AutoZone has it
Proportioning valve not included
States nothing about proportioning valve
thanks
I installed the new booster (old one hissed) and it improved the braking but the holding of the pedal is spotty. Grabs sometimes and others it will hit then slowly push towards floor. So I believe it’s the MC internal seals are not holding properly. I also purchased a new vacuum pump. So hopefully after all is installed and everything is bleed, I’ll have true brakes. Thanks Knotty.
on another note, I’m looking to change out my steering box. Do you know know a write up thread. The truck is a 2WD, if that matters.
Yes you can adjust the shoes with the adjuster wheel, the only thing I would do is to make sure the locking arm is holding tne adjuster wheel as it can back up and give you no brakes.
As for steering box, pretty straight forward 4 bolts hold it down on the driver side frame, one bolt holding the steering shaft in place, and the drag link has to be knocked out.
