01 f350 crew cab short bed 6speed build
#107
#108
#109
#111
Did a once over on truck installed a new ford steering shock had to shorten lower factory radiator hose about 1 1/2 in to clear. Truck drives leaps and bounds better than before old frontend was really good shape but still no comparison. Still need to swap the 05 up master cylinder in soon as I get the rearend swapped.
#112
Also need to pull the front lower crash bar off a parts truck I guess that’s what it’s called and have it sand blasted so I can powder coat it. And install it as well but definitely enjoying the ride quality so far eventually plan on some lift springs and thinking the better resivor fox shocks at some point.
#113
I have the icon 2.5 dual rate leveling springs and fox non reservoir shocks and it's rides good. When you do the rear end swap swap to 11+ 250 diesel rear springs. They ride way better in the rear.
When I first got done with my swap I had the icon front springs and 08 rear springs and front was wa abetter the the rear. Seemed like front was doing all the work. Swapped in a set of 11+ springs and it equaled it out a lot. Can feel the rear end actually working now like the front.
#115
#117
#118
I still have that lower gearbox shaft you can get the right end off of and then you will just need new bolts and gearbox. Everything else off the 05 will swap right over. Bolts you need are m16x2x140.
Rear 11+ springs you have to move front spring hanger forward but I'd imagine you can handle that. Cut it off then put the back rear most holes in bracket where the front holes went in frame. 2 line up and bolt it on then drill the others.
#119
