I have a 2022 Ford F250 Lariat Powerstroke and I want to put 37s on the factory wheels. I'm leaning towards the new 37x11.5 R20 Falken Wildpeak RT/01 tires. I've also purchased a Rough Country 2" leveling kit with the track bar bracket. I currently have 35×12.5 R20 Open Country MTs on the truck and they fit fine with no rub/scrub. Will I be able to add the 37x11.5 after the Rough Country kit and avoid the scrub?
Thanks in advance, new user. BTW, i searched and found all kinds of information back and forth and was wondering what the final verdict was.
They won't rub since they are 11.5. If you want 12.5, get the Hellwig 7712 front sway bar. The design of the angles keeps it away from the path of the wheel at full turn.
Lift isn't really going to play into fitment since it's the radius arms and sway bar that are rub points when using stock wheels. 37x12.5" on stock wheels is known to rub a little on those parts, but using an 11.5 should minimize or even eliminate that.
