Towing in overdrive
Old Nov 19, 2003 | 09:18 PM
keithf99's Avatar
keithf99
Towing in overdrive
I just bought a 1997 F-250 with a 7.3.and an auto trans. The truck has had an aftermarket transmission cooler with a small electric fan on the front of it. The truck turns approx. 2000 rpms in overdrive at 70 mph. I pull a 24ft travel trailer that weights 4500 loaded. Most of my towing is in flat country. The truck seems to pull the trailer fine at 70mph in overdrive. Any input on weather to tow in overdrive ?
Old Nov 19, 2003 | 09:33 PM
alanscott's Avatar
alanscott
I have about the same setup as you, but with a '95. I leave it in overdrive until I start up enough grade to cause it to drop into direct, then I just hit the OD lockout until the road flattens out again.
Old Nov 19, 2003 | 10:38 PM
bender97f250's Avatar
bender97f250
I have a 97psd also, I knock it out of OD once I hit a steep grade so the tranny is not searching back and forth between gears.
Old Nov 20, 2003 | 09:23 PM
DPMPSD's Avatar
DPMPSD
Put it OD and let it eat
