Noisy Fan Belts
Old Nov 19, 2003 | 08:10 PM
MRStace84's Avatar
MRStace84
Noisy Fan Belts
Anyone know a good way to silence noisy fan belts. I've tightened them as tigh as I can get them, but they are still noisy. Hoping someone might know a trick!?!?!
Old Nov 19, 2003 | 10:15 PM
locknkey's Avatar
locknkey
Some belts if they are too wide will whine, and otherwise if the pullys are bent or out of alignment...they will whine also. Just my 3 cents worth of experance.
Old Nov 19, 2003 | 11:59 PM
fishmanndotcom's Avatar
fishmanndotcom
you can buy belt dressing that will sometimes help...dunno never had the problem
-jason-
Old Nov 20, 2003 | 02:20 AM
jdon88's Avatar
jdon88
If you mean noisy as in loose, squealing belts then the belt dressing works great. I had that problem years ago and bought the dressing at Pep Boys, it either sprays or squirts on from a small container I forget. I do remember it being a little messy unless you use a rag or something to block the overspray.
Old Nov 20, 2003 | 02:22 AM
jdon88's Avatar
jdon88
I forgot to add...if you mean noisy as in a grinding sound then its probably one of your accessories (altenator, water pump, etc) with a bearing going bad.
