can you install the headers on my 390 on the the engine before you put the engine in the truck or do you hafta put them on after its in the truck, thanks.
Usually, depending on the headers you have to lift the engine a little bit. It is much easier to have the semi-mounted up when you drop the engine in. I didn't have to jack up the engine to get my flowtechs in but it was a royal pain in the rear. I would kinda lay them in place as you were carefully lowering the engine.
thanks sounds good, i think i am getting hedman headers there cheap, anything wrong with buying the cheap brand, i heard they rust out, cant u buy a paint that can withstand the heat so they wont rust so quickly
fordman and fordfan. Wow, thats kinda hard to distinguish. On low performance engines the high temp paint seems to hold. THe paint on my headers vaporized soon after startup and they are starting to rust. Not all the way through or anything. Just on the surface. Hedman has a pretty good reputation but a cheap header is a cheap header.
I put brand new Hooker Comps on mine... about $150 (they come painted black). It only has about 300 miles on it so far and, well, they ain't black no more! They started turning right away.
I put Headmans on mine, but I resprayed them before I put them on. The sticker tells you the "paint" if for rust prevention for shipping ONLY. Wonderful. I put some hi heat black on them. They smoke like a coal furnace for about an hour til it all burned off and now they are just kinda charcoal black. It's been a few months and NO signs of rust yet.
so more than likely what ever paint you put on them will be gone in a few days. o well i guess in a few years you can just call them throw aways and buy new when they rust away
i think it all depends on what you use your truck for too. for example i use mine every weekend mudding and of course all of the water and mud splashing on them has had a huge impact on how fast they are rusting out. (which is pretty fast) but i have on my tar baby the same hedman headers and they have lasted 4 years and no signs yet, so i think that what you do with your truck is a huge factor.
well mainly on the road its only a 2 wheel drive but i do plan on running high rpm's a lot, i have a lead foot and like to race, so i suppose they wont last real long do to heat.
Wrapping headers is a bad idea-they retain moisture and speed up the rusting and aging of standard headers. Good cerma coat headers are of course the, more expensive, answer. But they will be last time you buy headers.
well it sounds like you get what you pay for, just as well well buy some ceramic coated ones they you dont have to worry about it even if it is an extra couple hundred.
