brakes
Old Jul 30, 2023 | 09:07 PM
56fordguy's Avatar
56fordguy
brakes
where to buy front drums for a 56 f250
Old Jul 30, 2023 | 10:00 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
So, if I am reading the parts book correctly, here goes:
These front drums you are seeking will have 8 bolt holes on a 6.5 center, have a 12.125" inside diameter and a 2.51" brake surface width.
Front Drum part number: B6D-1125-A
Crosses with the below which can likely be ordered through your local parts store or found online:
NAPA ND 4401025
Raybestos 2618R
CENTRIC 12365016
DYNAMIC FRICTION 36554057
FVP 12365016
Old Jul 31, 2023 | 07:59 AM
56fordguy's Avatar
56fordguy
Thank you for answering , I looked up in the NAPA website. with all the correct info. I found the drum, said exact fit for my truck. i scrolled down under description and it says 10inch diameter and i need 12.125. Grrrr
Old Jul 31, 2023 | 08:29 AM
bmoran4's Avatar
bmoran4
I honestly think that may be an error on the specifications on the website. I would suggest using the website to identify any store that has the drum available for pickup today (indicating they may have it on the shelf), call the store, and ask them to measure the ID for you. You can also just order it, and refuse/return them if they are wrong - I've done that at my local Napa without issue.
Old Jul 31, 2023 | 08:37 AM
bmoran4's Avatar
bmoran4
Lastly, the discard diameter specifications is 12.19 inches (309.63 mm converted to inches) which is spot on for the correct drum.
RTT
24
May 22, 2023 03:10 PM
