Sorry for reposting this, but can someone please desktop dyno this
I have a 1967 ford 352 fe
bored 60 over with 9.0:1 cast flattop pistons
slightly ported stock heads
crank turned 10/10
mild street cam( listed below)
1 3/4" into 3" headers
2 1/2" duals into thrush glasspacks
Holley 2 barrel 500cfm
fresh rebuild no miles yet
(motor completely and heads completely)
What is the lobe separation and the intake centerline? If you have a part number for the cam I can get the rest. I will try to get you a graph by the weekend. Schedule is really packed right now.
Heres what I got. I didn't know the valve sizes from your heads so I let DD set them automatically. Probably has very little effect on the outcome. I also used the .050 numbers on your cam.
HP 286 @ 4500rpm. Fairly flat HP from 4000-5000.
Tq 390 @2000rpm. Flat Tq from 2000-3500.
I am very pleased with the results, my parents won't like this when they see the dyno, they will probably want to make me sell my truck, but I will try to stay out of trouble, I like the results, considering I wasn't trying for anything special, I was expecting more like 245HP and 350ft.lbs. thank you very much i appreciate you guys taking your time to do this for me.
