Oil Gauge
Old Jul 27, 2023 | 08:09 AM
eldomike51's Avatar
eldomike51
Oil Gauge
My 1995 starts up good every time...I noticed the oil pressure gauge in the dash never went very high, barely moving....I know these are basically on off switches but I would like for it to read in the center of the guage....I've replaced the sending unit and no change...I installed a mechanical gauge to check the oil pressure and it was 50 lbs at idle...any thoughts?
Old Jul 27, 2023 | 08:14 AM
knottyrope's Avatar
knottyrope
can get a new gauge or try to re locate the needle
possible wiring to switch is corroded and can clean teminals
oil switch activates analog oil gauge
Old Jul 27, 2023 | 08:42 AM
helifixer's Avatar
helifixer
you can gently pull the needle off of the shaft and put it where you want it, most point strait up.
Resendiz
May 13, 2015 06:32 AM
aweyerman
1997 - 2003 F150
Jul 14, 2012 04:18 PM
-ZIXXER-
Dec 28, 2009 07:34 AM
Donald Rohret
1983 - 2012 Ranger & B-Series
Feb 6, 2005 07:10 AM
theillest05
1978 - 1996 Big Bronco
21
Jul 4, 2004 11:38 PM
