Forscan help
Old Jul 26, 2023 | 02:16 PM
Eaglescout94's Avatar
Eaglescout94
Forscan help
I’ve got a 20 f350 with the 6.7, I have the extended forscan license and the recommended adapter. But I can’t seem to see yet alone access half of what I should be able to. Does anyone have an instructional video? Everyone that gets shared starts halfway through or isn’t instructional at all.
Old Jul 26, 2023 | 05:07 PM
Eaglescout94
This seems to be what everyone else gets, got the pic from the forscan thread. I only show maybe 4 modules and the related categories for those 4.
Old Jul 26, 2023 | 05:52 PM
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
can you post a photo of your adapter, also what version of ForScan are you using ?
Most answers can be found in the ForScan sticky at the top of this subforum
ZooDad
Old Jul 26, 2023 | 11:59 PM
Eaglescout94
Here’s what I bought, pretty sure it’s the one recommended in the sticky.
As for forscan, I’ll have to double check the version when I get home but it was updated a week ago.
Old Jul 27, 2023 | 07:49 AM
cpobst's Avatar
cpobst
When it asks if it's your truck from last time you used it (I can't remember the exact terminology) click No. it may take some time to recognize all the modules but each time you use it you should let it think it's a truck you've never hooked up before. Make sense?
Old Jul 27, 2023 | 08:30 AM
kry226's Avatar
kry226
I always use the same profile and have never had issues. Why would you want fifty eleven profiles of the same truck?
Old Jul 27, 2023 | 08:34 AM
cpobst's Avatar
cpobst
Because I had the same problem once. Contacted Forscan and that was their advice. If it's working fine then keep but if you start having issues like the OP I would recommend what I previously stated.
Old Jul 27, 2023 | 08:40 AM
ZooDad's Avatar
ZooDad
@cpobst is absolutely correct. Never save profile never load a profile. I have seen freeze frame DTC stay that weren’t actually active.
@Eaglescout94 have you updated the EX firmware ?
ZooDad
Old Jul 27, 2023 | 08:53 AM
Don Ridley's Avatar
Don Ridley
This explains the purpose of vehicle profiles. Creating a new profile is the fix for a lot of problems.
https://forscan.org/forum/viewtopic.php?f=5&t=9196
Old Jul 27, 2023 | 09:24 AM
Mr. Donevan's Avatar
Mr. Donevan
4wd Low
I too am in the same boat. I am willing to pay for instruction but my funds are very limited. I have recently bought December 2022, a 2012 Ford 550 Super Duty 4X4 with only 12,00km's and I don't want to screw up my truck as Forscan is a very powerful tool that can solve problems or create problems. I know I don't know enough to use Forscan safely. I also ask are builds for Canada different than USA builds and or how different requirements of laws affect the use of Forscan? I would equate the use of Forscan to tinkering with your computers bios one mistake or miscalculation can cause disaster. I was intending on primarily using Forscan for two uses to find out want codes are being triggered so I can resolve them and or to clear the codes and then I can see what is going on in the here and now.
Donevan donevan@outlook.com 519-981-7567. I live in the Windsor, Ontario and across the river is Detroit. If you find some good materials can you shoot me a link?
Old Jul 27, 2023 | 09:32 AM
Don Ridley's Avatar
Don Ridley
Using Forscan as a diagnostic tool is 100% safe. Reading DTCs and monitoring data will not change anything in the vehicle's modules (ecu's). But understanding the data takes research and experience.
Old Jul 27, 2023 | 09:33 AM
ZooDad's Avatar
ZooDad
check out the tab “ForScan Help” in the spreadsheet. There are members from all over.
ZooDad
Old Jul 27, 2023 | 10:14 AM
Eaglescout94
I’ll definitely hook up and load without using the pre-existing profile. I think I made that with the old adapter and possibly not updated forscan. The new adapter I have was upgraded last time I plugged in to try and add some stuff.
Old Jul 27, 2023 | 10:26 AM
cpobst's Avatar
cpobst
Let us know if that resolves your issue.
Old Jul 27, 2023 | 02:29 PM
kry226's Avatar
kry226
ZooDad
Good to know! WILCO!
