Driver's side CAC pipe
Old Aug 1, 2023 | 12:47 PM
RA101725's Avatar
RA101725
Banned
So I guess I'm not doing too bad then with the ziptie holding just the right amount of upward pull to keep it off that P/S pump fitting, Not a huge fan of redneck engineering like this but It's been that way for literally years now as the best fix I could come up with. Never thought to actually pad up/cover the P/S pump part with a rubber boot but I suppose that works too. The pipe itself is the problem but mayyybe swapping the boots for the thicker Riff-Raff ones that have less give or flex to them would hold the OEM pipe steady enough to where it has no further interest in rubbing on the P/S pump. That might be a cheap(ish) realistic fix to try for lack of a pipe that just works.
Old Aug 1, 2023 | 12:50 PM
RA101725's Avatar
RA101725
Banned
Originally Posted by Kwikkordead
OK, I guess I'm never too old to learn. I've seen a lot of abrasion wear over the years in different situations as someone making a living fixing other people's vehicles. But if this lasts that long, then I guess it's good.
Problems like that all over my truck and I get tired of having to keep track of them all
Overkill2
6.7L Power Stroke Diesel
29
Jan 2, 2025 09:29 AM
Dean06919
Sep 10, 2020 09:08 AM
J_Justin
Oct 6, 2019 06:12 PM
suzuki0702
May 3, 2019 08:54 PM
NJTy180
Jan 19, 2006 05:59 PM
