Window goes down automatically
Old Jul 21, 2023 | 06:09 AM
Davetut019's Avatar
Davetut019
I replaced the battery on my 17 XLT on Wednesday. Now when I roll down my passenger window, then put it back up, it will automatically roll back down. Once I put it back up, it is fine. Any theories on why this might happen?
Thanks
Dave
Old Jul 21, 2023 | 07:14 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Sounds like the bounce back is working, like when something blocks the glass from fully going up.
Try resetting it by rolling the window all the way down, holding the button down for a few seconds after it is all the way down, then do the same thing in the up position.
Old Jul 21, 2023 | 08:25 AM
Davetut019's Avatar
Davetut019
Thanks. I will try it when I get home after work…
Old Jul 21, 2023 | 09:03 PM
KU4OJ's Avatar
KU4OJ
It seems the window has forgotten where the top of the window frame is and thinks it has hit an obstruction. There is a calibration procedure described in the owners manual. Ltngdrvr's post seems about right.
Any chance the window was down while you were swapping the battery?
Old Jul 21, 2023 | 10:58 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
That was my thought, but either way the reset should fix it.
Old Jul 22, 2023 | 08:39 AM
Davetut019's Avatar
Davetut019
I had to do the reset thing a couple of times, but it did work, and everything is good. Thank you for your help, I appreciate it.
Old Jul 22, 2023 | 08:40 AM
Davetut019's Avatar
Davetut019
Actually it was down when I swapped the battery out.
Old Jul 22, 2023 | 09:15 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Yeah, thought that might have been, that is definitely what upset it.
Glad the reset worked out.
Old Jul 22, 2023 | 09:38 AM
KU4OJ's Avatar
KU4OJ
So the take away is, roll up all the windows before changing the battery.
Ain't that something?
Old Jul 22, 2023 | 10:11 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Could be a task if the battery is completely dead.
Ocastillo
Mar 7, 2021 12:31 PM
f-150 on 22's
2004 - 2008 F150
Sep 4, 2007 09:11 AM
Cameo
1978 - 1996 Big Bronco
May 27, 2003 11:42 PM
