Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
90 amp mig enough?
Old Nov 19, 2003 | 01:48 PM
drewcoolness99's Avatar
drewcoolness99
90 amp mig enough?
I have a chance to buy a 90 amp snap on mig welder for $200 and I am staring to wonder. How much can that do? Like can I do exhaust systems with it? What would be too much for it?
Old Nov 19, 2003 | 03:11 PM
FortyFords's Avatar
FortyFords
Save your money and get a real mig !
175-200 amp /230 volt mig
multi purpose
Lincoln
Miller
Hobart
Rich
Old Nov 20, 2003 | 12:11 AM
zsir's Avatar
zsir
90 amps will do up to 1\8" mild steel....
Old Nov 20, 2003 | 03:02 AM
Mike W's Avatar
Mike W
With .035 solid wire and CO2 my welder is putting out 100 amps. It is a 200 amp Hobart so it doesn't even get warm. Try to get a 220 volt machine.
Old Nov 20, 2003 | 11:48 AM
tgregoire's Avatar
tgregoire
Hey Mike,
I must have missed something because I don't understand what you saying....it sounds like english but I don't get it.
Old Nov 20, 2003 | 11:59 AM
tgregoire's Avatar
tgregoire
Drew,
If you are on a tight budget and only need to weld body panels and exhaust stuff then I would buy it. You can always upgrade later. Or buy a stick welder for the thicker stuff. I have a cheapy 220 volt welder, it only puts out 140 amps max but I have done a ton of stuff with it, if I'd have waited until I could afford a REAL unit, I'd still be waiting. I'm working on a 53 F100, the only thing I've run across which is thicker than 1/8" is the hinges I made for my tilt nose. Heck, even the frame of my truck is only about 1/8" thick.
So in other words, there is alot you can do with that welder.
Old Nov 20, 2003 | 01:26 PM
Mike W's Avatar
Mike W
With my .035 diameter wire the machine has to put out 100 amps of current to weld. 90 amps would not be enough. .023 wire would take less current.
.023 would work on exhaust systems. It is a little small for stuff using 1/8 thick material. Every welder has a duty cycle rating. This is how many minutes out of 10 that you can weld before you need to let it cool down. As the amps go up, the cooling time increases.
My Hobart has a 60% duty cycle at it's max output of 200 amps. At 100 amps it is much higher. Some welders are 20% duty cycle at max output.
Old Nov 20, 2003 | 09:35 PM
drewcoolness99
Originally posted by tgregoire
Drew,
thats what I figured too. And its a Snap On so I know it will hold some value. For 200, I get a welder, bottle and extra spools too.
Old Nov 21, 2003 | 07:04 AM
tgregoire's Avatar
tgregoire
To get the bottle and regulator cost me almost $200 alone. So if that's part of the deal then you are that much further ahead of the game.
Good luck with the new toy.
Old Nov 21, 2003 | 08:35 PM
Airbrush's Avatar
Airbrush
I haven't heard anyone complain about a Strap-On welder and I can think of about 6-8 who use them daily. You could probably get that for it even if you decided you didn't want it and re-sold it.
Old Nov 24, 2003 | 08:22 PM
shortbed1's Avatar
shortbed1
welder
Hey drewcoolness, What model welder is that i can tell u all about it with a model # old snappy dealer
Old Nov 24, 2003 | 08:45 PM
Larry Heath's Avatar
Larry Heath
If your going to buy a welder buy as big a welder as your pocket can stand and then some. Sure you can weld a lot of things at 90 amps, but your going to be welding at 90 amps most of the time and your not going to get much welding done. The duty cycle on that machine at 90 amps is more than likely about 20% ro 30% i.e weld 2 or 3 minutes set and wait for the unit to cool for 7 or 8 minutes. Cheap is as cheap does.
Later Larry
Old Nov 24, 2003 | 10:42 PM
dashashopdog's Avatar
dashashopdog
a 90 amp will do what most people want to do at home. i have a 125amp in my shop. i have no problems with it welding 1/4" plate. my brother in laws 90 campbell hausfeild will do the same with a little tinkering. v cut and a 90 amp will do 5/16. it isn't always the size of the wave, but the motion of the ocean. this also applies to welders. anything heavier than 5/16 and i always bust out the arc. mig doesn't have the best penetration with large gage steel like an arc does. what do you think built the liberty ships in the oakland ship yard during WWII? anything larger than 125 amp is nice, but strength will be a real problem, expecially with a novice welder. i have yet to see a novice welder get poor penetration with an arc welder. a 90 amp welder will do if you are keeping in under 1/4 or 3/16 plate. do you really realize how thick those metals are? mine has a 35% duty cycle 3.5 minutes is alot of welding on 3/16 plate. like 32 inchs of an unbroke weld. anything below 20% is way to slow though. but a simple external squirrel cage fan can easily double the duty cycle for less than 30 bucks.
Old Nov 25, 2003 | 10:09 PM
drewcoolness99
Re: welder
Its a Snap on Professional tote YA217A
with the bottle, he got a good deal from the body guys when he worked at a ford dealership. so I got it for $200
Old Nov 27, 2003 | 08:42 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Buy as big as you can afford, you won’t go wrong.
