I recently pulled the plug wires on my '92 F-150, 5.0L to put on another truck. It ran when I pulled the wires then when I went to put new wires and plugs in it would not start. I have spark from the coil and to all of the plugs but the plugs seem not to be getting any fuel. Any ideas would be great.
Here's an update. I parked the truck for a while because I did not have time to work on it. I spent today checking somethings and here is what I discovered. I pull 3 codes 114, 116 and 636. I testesd the ACT and it was fine.
I hear the fuel pump turn on.
I get spark
I remember a couple of months ago that While I was driving the truck started to sputter and act like it was out of fuel. I pulled over to the side of the road and it started after a few minutes. I also have had trouble at times with it running really rough when I first start. It is intermitent though. I didn't give much thought to these because it ran until now.
I had a problem something like that on my 5.8 and after checking everything for 8 hours i discovered it was a fuse. But its not always that easy. Good luck
