Replace Flasher Relay
Old Jul 18, 2023 | 12:05 AM
Ettiquartz's Avatar
Ettiquartz
2nd Gear
Question Replace Flasher Relay
Model: 2003 Ford Ranger XLT 2-Door Super Cab
My front right turn signal will not blink, despite the bulb lighting normally when the light switch is set to "running lights". The dash turn signal indicator flashes rapidly as if there were a dead bulb. After research, I determined that the culprit is the flasher relay. I looked for instructions on removal and found nothing useful. I inspected the mount thoroughly and felt no clips or screws. Assuming that it's retained with friction only, I tugged on it, but the force needed seemed too high (junction box was flexing heavily). I don't see any corrosion, tape, or adhesive.
How do I properly remove the flasher relay? Every video I have found jump cuts the money shot, which makes me suspect that this is a serious pain. I don't want to break anything.
Old Jul 18, 2023 | 04:02 PM
Black3's Avatar
Black3
4wd High
Flasher
I've never seen one that doesn't just pull out. It must have corrosion in the electrical prongs. Just enough to cause problems.
Old Jul 18, 2023 | 09:15 PM
Ettiquartz's Avatar
Ettiquartz
2nd Gear
Thanks for confirming the method of attachment. Now, I can move forward with addressing the stiffness.
Noneya
Apr 12, 2025 03:50 PM
dvldog458
Aug 26, 2024 07:07 PM
medicanic7
Jul 14, 2021 05:35 AM
noober0x
Oct 30, 2015 07:04 PM
dwetopgun
Electrical Systems/Wiring
Jun 30, 2003 11:24 AM
