Air delete plug head
Old Jul 19, 2023 | 07:03 PM
GreenMountain95's Avatar
GreenMountain95
OK I will check the o2 sensor .
And sandwich a sheet of metal to block off EGR .
Old Jul 20, 2023 | 05:44 AM
torq'ta 5 8's Avatar
torq'ta 5 8
check for codes? could lead you in right direction, also, you'll aaat least, have EGR code, cause vacuum removed.
Old Jul 20, 2023 | 07:25 PM
GreenMountain95
I had no other codes but EGR .
just code 332.
Which is strange I didn't get any air Injection codes .
I'll have to run them again, must be forgetting or read them wrong .
im just counting check engine lights no code reader
Old Sep 23, 2023 | 06:23 PM
GreenMountain95
I haven't had the time to dig into the issue yet , haven't put a ton of miles on the rig since last update .
Had a couple people give me their opinion on the exhaust smell , they said they didn't notice anything and just smells like an old truck . It hasn't smelled as rich to me either of late .
I've been doing short trips (maybe 10 miles max one way ) mix highway and stop and go city, dump run , hauling a little over a ton for half the miles driven, and got Average 10.5 Miles per gallon . That isnt half bad ! Running on Mostly 92 octane in the tank. Big improvement over the 7.5 mpg that caught my attention .
A couple questions for you guys ,
Does the fuel system go into open loop when idling ?
haven't noticed any pinging with EGR Vaccum unplugged (10 BTDC timed, and usually 87 octane fuel) Just the EGR CEL,
Would the block off plate and hook back up vacuum then cause it to ping ? And it's only not pinging now because no vacuum, and system won't change timing advance due to no vacuum , so EEC thinks the EGR is not functioning?
pokinyourmom
Mar 9, 2010 07:44 AM
steve_speak
16
Dec 9, 2008 07:18 PM
Kylet8020
Oct 26, 2007 12:59 AM
Parasite
1947 and Older Ford Trucks
15
May 11, 2004 02:07 PM
