351M pistons
Old Nov 19, 2003 | 11:00 AM
faceplant's Avatar
faceplant
Cool 351M pistons
I am rebuilding the engine in my sons truck and on top of the piston's, there is a "40" stamped on them. Does that mean that it has been bored 40 over or just that it signify's a 4 inch bore? Thanks
Old Nov 19, 2003 | 03:55 PM
inliner240's Avatar
inliner240
40 on a piston usually means .40 over...sometimes when they rebuild engines they stick a tag on the side of the block somewhere that says whats been done to it but if there was one there it probly fell off.
Old Nov 19, 2003 | 07:11 PM
Torque1st's Avatar
Torque1st
Posting Legend
That block is probably shot. Have a machinist measure it. You will need to find another one. That 0.040 overbore is close to the limits as it is and probably over with wear.
When you get a new block get a 400 for a performance boost. The engines are the same outside so everything will bolt on.
