Sponsored by: Real Truck
2016 f350 engine swap help
Old Jul 11, 2023 | 12:12 AM
maksim's Avatar
maksim
1st Gear
Hey, I have a 2016 6.7 diesel. I need a new engine. I found an engine but it’s from a 2011. Does anyone know if the block/bottom end are the same from 2011-2016? Would it be possible to get the 2011 and use as a block/bottom end and swap my 2016 turbo, injector, fuel system, outer everything over to the 2011? And would my ecu work with the 2011 if I swapped everything over.
Old Jul 11, 2023 | 12:43 PM
cj45lc's Avatar
cj45lc
If you just use the bottom end I think you have a good plan, the early exhaust valves are suspect.
640 CI Aluminum FORD
7.3L / 6.8L V8 Gasoline Engines
Apr 14, 2019 09:03 PM
DSLPOWR
Apr 3, 2019 09:34 PM
