Swapping to a bigger engine
Old Jul 11, 2023 | 07:01 PM
Sparky04SD's Avatar
Sparky04SD
For the expense of an engine upgrade and your intended use I think if it's a 2WD truck you would be better off keeping the 302 and changing your rear axle ratio, You're probably running 3.54's which are not "tow friendly" when using a 302. Swap to ether 4.10's or 4.30's if you can get them. Cheapest way is to swap complete rear end. You'll be surprised how that 302 will pull with some 4.10/4.30 gears. I've pulled 6000# behind the F150 in signature and it did a great job for me.
Old Jul 12, 2023 | 06:12 AM
acrockett6's Avatar
acrockett6
It's 4WD, I really do need to go look at what the axle code is on the inside of my door to see what gears are on my truck. I'll try to do that today.
Willy2763
13
Mar 31, 2022 10:26 AM
Overdriveisoverrated
Dec 21, 2019 08:37 PM
Rebel 84
Feb 11, 2015 02:14 PM
jowens1126
1978 - 1996 Big Bronco
Feb 24, 2014 11:19 AM
4xfreak
34
Jul 27, 2006 04:14 PM
