Another burnt Ford
Old Jul 9, 2023 | 09:46 AM
eminence1963's Avatar
eminence1963
Another burnt Ford
https://kpq.com/vehicle-fire-on-i-90...ver-100-acres/
Old Jul 9, 2023 | 10:06 AM
Charlie98's Avatar
Charlie98
Doesn't say diesel or gas...
Old Jul 9, 2023 | 10:34 AM
Kameron Rice's Avatar
Kameron Rice
garentee you it was a diesel, the 17-19 fuel filter return line under the good breaks off, sprays fuel everywhere. Mine did that last year and in 3 miles i drained 15 gallons of diesel and the insulation on the dpf was smoking for hrs. Made a huge mess.
Old Jul 9, 2023 | 12:00 PM
Rwhjr's Avatar
Rwhjr
Wtf isn’t this a safety recall by now to prevent massive damage and potential loss of life?
And if it is then negligent owners need a kick in the nuts for not getting that done.
Old Jul 9, 2023 | 12:16 PM
4wd6.7L's Avatar
4wd6.7L
The 17-19 fuel filter kits started including a reinforcement clip to mitigate breakage of the one sensitive fuel line. They also started coming from the factory with that clip installed at some point (my 19 came with it). The reality is, a failure can happen in various ways. Careless fuel filter install, failure of a seal, or as we have seen before, the plastic filter housings sometimes springs a leak out the top.....that's assuming diesel.
Old Jul 9, 2023 | 12:22 PM
FishOnOne's Avatar
FishOnOne
It's still mind boggling that the fuel filters are installed on top of the engine dating back to the 6.9 IDI engines.
Old Jul 9, 2023 | 12:49 PM
redford's Avatar
redford
FTE Leadership Emeritus
Looks like an enclosed car hauler and an unidentifiable car were also destroyed. The residents of Vantage must have had a great view of it all.
Old Jul 9, 2023 | 01:04 PM
Team Bob's Avatar
Team Bob
That happened to me and my wife 130 miles from home. The top fuel filter cracked and sprayed diesel everywhere under the hood. A good samaritan saw my dilemma. He went home and removed the filter from his WIFE"S F250, and came back and installed it. Would not give me his name, address or anything. All I could say was thanks!
Old Jul 10, 2023 | 12:22 AM
Adam R's Avatar
Adam R
O-rings failed on my fuel filter (2019 diesel).....3000 miles after I changed it. Ended up spraying fuel everywhere. I was able to re-set the o-rings and it got me home. I then took some measurements and found an O-ring at ACE hardware that provided a better fit than the factory green and yellow o-rings.
No problems for the last 10,000 miles.
Crap design for sure.
Old Jul 10, 2023 | 02:56 AM
twobelugas's Avatar
twobelugas
you must looked so sketchy that he wanted you out of his town ASAP with no excuse to linger.
Just kidding. That's a good guy indeed.
F350 1990
Computer Chips & Tuners
Dec 9, 2024 03:54 PM
1952henry
1947 and Older Ford Trucks
Sep 30, 2017 03:13 PM
