power window gear
Old Nov 19, 2003 | 07:44 AM
ksvtwin's Avatar
ksvtwin
power window gear
The advice from the board has helped me so much. I have a '93 F150. The drivers side power window is not working right. i can hear the motor run but the window won't move. a couple weeks ago it was clunking when it reached the top and i thought it sounded like a nylon gear was finally stripping off or something. Is there such a gear in there and what is the best way to go about replacing it? Thanks, Kent
Old Nov 19, 2003 | 08:35 AM
m14dan's Avatar
m14dan
Actualy it should be the same as mine. If it is there are three I think plastic rollers in the motor that blow apart after time. I buy them in big bags because I do them so much at work but you can get a kit at the ford dealer for just a few bucks to replace them. Take your motors gearbox cover off and see if it is the same. I have never had to replace a motor yet on an older truck. Just those rollers in the gear box. It's real easy once youve done a couple.
Old Nov 19, 2003 | 08:50 AM
ksvtwin's Avatar
ksvtwin
Thanks, do you have to remove the motor from the door? Is that difficult todo?
Old Nov 19, 2003 | 11:26 AM
m14dan's Avatar
m14dan
No it isn't too hard. Some are riveted and some just have screws. It's pretty easy. All you have to remove is the motor. Not the whole regulator.
Old Nov 19, 2003 | 11:37 AM
shorebird's Avatar
shorebird
I did a window motor repair job on a '87 Dodge van last week. I had to drill out the rivets holding the motor and crank assembly. The gear sets were shot but the motors were fine. The dealership wanted $69.70 + tax for one gear set. I got them at O'Rielly for $15.87 ea. When I reinstalled the assembly I used nylon insert nuts on the bolts replacing the rivets.
Old Nov 23, 2003 | 04:49 PM
steve83's Avatar
steve83
Old Nov 24, 2003 | 12:44 PM
ksvtwin's Avatar
ksvtwin
Thank you!! I will tackle it over the thanksgiving weekend. strangely it started working again but I figure it's just that the rollers must be in position. as soon as they slip again, it'll stop working.
