Sponsored by: Auxito
AC relay??
Old Jul 8, 2023 | 02:42 PM
Airborne 82nd's Avatar
Airborne 82nd
AC relay??
1997 f150 base model 4.6 I found the fuse (good) by my left foot 15a position 5. The clutch is not pulling in. I found it odd that there is no relay for the clutch. Later years do have one. Can someone confirm this? Next step is to jump out the low side switch I hope it is bad. Then the high side. If they both check good time to power probe clutch. Any other ideas are welcomed.
Airborne
Old Jul 8, 2023 | 05:33 PM
projectSHO89's Avatar
projectSHO89
Yeah, the first couple of years of that generation of F150 didn't use a relay, the clutch was controlled by the series circuit of F05>mode switch>high pressure switch>low pressure switch>clutch. All you have to do is go along the path with your meter or test light and see where the control voltage gets lost.
Old Jul 9, 2023 | 07:43 AM
Airborne 82nd
@projectSHO89
Thanks for the fast response. Now do you know where the low side pressure sw. is hiding? I found the low side charge port and the high side port.
Old Jul 9, 2023 | 08:31 AM
projectSHO89
It's going to be on top of the accumulator or its adjacent lines.
Old Jul 9, 2023 | 04:08 PM
Airborne 82nd
OK thanks I have followed the line but did not see it. I think you are correct about the accumulator it may be covered up with all the wires from that J-box above it.
Again thanks
Airborne
Knotwild
1997 - 2003 F150
Sep 12, 2021 02:09 PM
MichaelA2014
Jul 21, 2017 07:34 PM
FrankCZ
Jul 28, 2016 08:44 PM
thebilger
Feb 2, 2013 01:51 PM
traves
Dec 19, 2003 09:50 PM
