I have a 2000 Ford F-150. My cruise control quite working. I have checked all of the fuse and the break lights and the cable that connects to the throttle body. Any help
Check the brake pressure switch. I have a 1998 F150 4.6L and the cruise quit working because the brake pressure switch failed. Mine was on the end of the master cylinder with two wires connected to it. It looks like the old oil pressure switch. Check continuity while someone operates the brake pedal. Also check to ground for a short. It was cheap and easy to fix.
I just purchased a used 1998 F-150 as well, has the 5.4L. My cruise does not work, and I see what looks like an oil pressure sending unit on the master cylinder, but nothing is plugged into it. There is a little fluid running down the side of the master cylinder as well. Where would the wires be coming from to hook into this brake pressure switch? Thanks,
The two wires are about six inches long and then tie into the main wiring harness located just forward of the master cylinder. They appear to go to the speed control module (attached to drivers fender with a throtle cable attached) but they are wrapped up so I can't tell for sure. There should be a molded plug hanging loose some where or at least some cut wires.
Mine too was leaking fluid and started to smoke. I guess it shorted out that's how I found it. I woke up one morning to find my garage full of smoke. That was fun.
Thanks for the response. I found the plug last night, and the brake pressure switch on mine is leaking too. When I tried to plug them together, I got smoke and more leakage like you described. I disconnected, and per a Ford Tech I talked to on the phone yesterday, he said I could jumper the plug with a paper clip to see if it works. It works fine.....and depressing the brake pedal still kills the cruise instantly. I am going to replace the pressure switch, but am now unsure of what it actually does. Anyway, thanks for your response.
The Ford dealer will know. I beleive it's a universal make or break pressure switch.
As for what it does. In addition to the cruise control I could not get the truck out of park with out it. The engine would start but you weren't going anywhere. I had to turn the key to on (not start) Shift to neutral and then start the engine to be able to drive it. Once in park with the engine running it would not shift. All things working correctly. You start the engine, step on the brake (there's a click sound) that's the brake pressure switch releasing the transmission to shifted.
