Hard Starting
It is so intermittant I am reluctant to take it to the dealer. Any thoughts would be appreciated.
My first thought is that 1 or more of the injectors are leaking down.
Also, the AIC valve seems to be a common culprit for sypmtoms like you described.
How may miles do you have on your truck?
Are there any other driveability concerns?
Does it only happen on a cold start?
>leaking down.
I didn't notice any great amount of smoke, possibly grey if any.
39,500 miles +/-
Once it starts it runs fine. It took 3 tries the first time and 4-5 tries the second time it happened.
Yes, both times it was a cold start (overnight)
Where is the AIC valve? Can I check it?
Thanks.
Anyway...it is located on the back part of your intake manifold. I believe there is a two wire plug going into it that operates the solenoid. The valve itself is held on by some bolts. Take it off and inspect. There may be carbon build-up in it. Get some carb cleaner and clean it out to free up the plunger.
Many have reported that doing that or replacing it (about $85 or so with gasket) will solve the hard start. Try and clean it first, of course.
Is your truck equipped with an EGR system?
I have to confess that I don't know. I will check it out tonight.Can I remove, clean and reinstall the valve without replacing the gasket? Or do I need to get a new gasket first?
Thanks.
