"slow" alternator
Old Nov 18, 2003 | 11:21 PM
laynrubber's Avatar
laynrubber
"slow" alternator
Now that the temps are below freezing i am noticing something on this truck and i'll throw it for anyone with an idea.
My truck has a one wire GM alternator and it works great......but.
When i first start it in the morning the alternator doesn't "come on line" right away.
I'll explain; i have a voltmeter instead of an ammeter in the dash and once the truck is started and running at warm up speed (1500rpm) i look at the guage and it is reading battery voltage....12 v, it takes a minute or so and then the lights get brighter, the fan speeds up and i see that now the voltage is at 15.5 or so.
My 79 did that when it got cold and i found that the ignition switch needed a jiggle (till i lubed it)
I have jiggled the ignition switch and tried to "surge" the electrics by switching on the lights and heater on high but to no avail. It's almost like something in the charging system needs to warm up.
So far as long as the system starts to charge i can live with this.
Any ideas ??
Old Nov 18, 2003 | 11:47 PM
texasbob's Avatar
texasbob
I had a similar problem a few years back, the lights would get brighter and dim at random, and the ammeter would show it. Turned out to be the alternator going out. take it to the local parts house, they should be able test it for you.
Bob
Old Nov 19, 2003 | 04:56 AM
Jim VA.'s Avatar
Jim VA.
Shaune; The GM alternators with internal regulators, will have to reach a certain RPM before they will start to have output. Have you tried increasing RPM on inital start up ? Perhaps after your cold engine warms up and gains RPM the regulator kicks in and everything would work ok. Jim VA.
Old Nov 19, 2003 | 03:35 PM
BobJonesSpecial's Avatar
BobJonesSpecial
Jim VA is correct that GM alternators have to reach a certain RPM before they self energize and lite up. A solution might be to go to one slightly smaller pulley size on the alternator to speed it up without having to wrap the engine to higher RPM.
BobJonesSpecial
Old Nov 20, 2003 | 12:50 AM
laynrubber's Avatar
laynrubber
Well the alternator is new....less than a year.
It should be on line at 1500rpm, and yes it has reved higher on start up and still not clicked on.
I think for amusement one day i will put a heater on the alt and let it prewarm up, then start the truck just to see if the alt needs to "warm up" before producing.
Old Nov 20, 2003 | 08:38 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Having to bring the rpms up to begin charging is a normal trait of the one wire alternator. One of the wires eliminated is the "exciter" wire which in a 3 wire makes it start charging immediately. However, I would think 1500 rpm would be enough to bring it online. I've never heard that they have to warm up. Perhaps you got a bad one...
gearloose1
Jan 1, 2020 05:03 PM
LipschitzWrath
22
Aug 14, 2017 05:22 AM
lambone
Jan 10, 2015 09:44 PM
rmalicki
Jan 26, 2010 08:10 PM
STBickerton
1983 - 2012 Ranger & B-Series
Apr 15, 2007 12:57 AM
