I have a 2017 f150 with warnings coming on intermittently 63000 miles
service advance trac
hill start assist not available
the wrench. See manual
please any help with these issues not ready to take to ford
to tell me they can duplicate the problem.
Best if you can ready the codes at least. If you can't do that, could reset everything by disconnecting the battery overnight if you wanted, but I'd prefer to read the codes first.
Sounds like something with the brakes, but hard to diagnose without the codes.
those were the same warnings i had with a bad throttle body (vehicle would only idle even with the accelerator pressed), but I'm sure there are multiple failures that will also trigger those...as previously stated, any stored codes would help (if there are any)...
