93 302 tach not working
Old Jun 29, 2023 | 09:46 PM
Andrew Losinno's Avatar
Andrew Losinno
Hi all, have been trying to figure this problem out for years, ever since I got my truck 3 years ago my tach has never worked. When I first got it if I banged on the dash a little it’d go for a little amount of time but then get stuck at 1300 rpm and only shoot up to around 5-6 grand when I really get into it. Just wondering if there is some sort of sensor somewhere I could check or if it’s just the gauge itself that is busted. I was thinking about just swapping in a gauge cluster w/o a tach and getting an aftermarket auto meter one.
Old Jun 30, 2023 | 06:36 AM
My4Fordtrucks's Avatar
My4Fordtrucks
I don’t know what it is with people beating on the dashboard of their vehicles.
To me, it sounds like there is a bad connection or the gauge is bad. Take the cluster out and inspect the connections for corrosion or loose terminals. It would be easier to replace the factory tachometer than it would be to replace it with a non-tach cluster. You don’t even need to remove the cluster to replace the gauge. Not only that but than you mentioned installing an aftermarket tach which would require you to wire it up and install it somewhere.
Old Jun 30, 2023 | 07:22 AM
Prototypemech's Avatar
Prototypemech
If the needle is getting stuck, then that sounds like a gauge issue, not a wiring issue or sensor issue. Just replace it with a eBay or junkyard gauge cluster.
Old Jun 30, 2023 | 09:02 AM
manicmechanic007's Avatar
manicmechanic007
That is why you smack the dash
Now you know the signal is there and you need a new tach
Old Jun 30, 2023 | 10:36 AM
toolman60's Avatar
toolman60
On my daughter's Ranger her tach was doing same thing. I took tach out of dash and cleaned the pins and contacts with a
Fiberglass Scratch Brush Pen
been working great since.
Old Jun 30, 2023 | 02:07 PM
My4Fordtrucks
Nope. Not convinced that beating on old plastic parts is a good diagnostic procedure. If the window sticks, I suppose you would advise someone to punch the door a few times?
blifsey
Jan 13, 2025 12:46 AM
Brett5.0f150
Nov 17, 2022 12:07 AM
OldWoodsDiesel
13
Mar 3, 2013 10:26 AM
LARIAT 85
Apr 17, 2009 09:33 PM
wulfcity
Apr 16, 2003 06:31 PM
